Код
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using Autodesk.Max;
using Autodesk.Max.Plugins;
namespace Plane
public class PlaneDescriptor : ClassDesc2
IGlobal global;
internal static IClass_ID classID;
public PlaneDescriptor(IGlobal global_)
this.global = global_;
classID = global.Class_ID.Create(253674,23564);
public override string Category
get { return "Max .NET Tutorial"; }
public override IClass_ID ClassID
get { return classID; }
public override string ClassName
get { return "Plane"; }
public override object Create(bool loading)
return new Plane();
public override bool IsPublic
get { return true; }
public override SClass_ID SuperClassID
get { return SClass_ID.Geomobject; }
public class Plane : SimpleObject2
public override void BuildMesh(int t)
public override ICreateMouseCallBack CreateMouseCallBack
get { return null; }
public override RefResult NotifyRefChanged(IInterval changeInt, IReferenceTarget hTarget, ref UIntPtr partID, RefMessage message)
return RefResult.Succeed;
public static class AssemblyFunctions
public static void AssemblyMain()
var g = Autodesk.Max.GlobalInterface.Instance;
var i = g.COREInterface13;
i.AddClass(new PlaneDescriptor(g));
using System.Linq;
using System.Text;
using Autodesk.Max;
namespace Plane
IGlobal global;
return new Plane();
Ставлю dll в /bin/assemblies, но макс вылетает при запуске.
Все вроде просто и понятно, но не работает скотина.
