| Home· Статьи · Downloads · Чертежи · 3D Галерея · 2D Галерея · Форум · Форум Realtime · Чат | Реклама |  Конкурсы | RAR Award | Правила |
30/10/2007, 14:40
Эксперт Группа: Участник Сообщений: 505 Регистрация: 26/09/2006 Из: Москва Пользователь №: 37 543 |
NUK101: Introduction to Nuke
Description: Taught by Sean Devereaux, this course will get you up and running on version 4.7 of The Foundry's Nuke compositing software. The software will be available over the VPN to fxphd posgrads for non-commercial use (OSX, Linux, and Windows versions). The course starts with an overview of Nuke and how it differs from other apps like Shake or Flame and then dives into multi-channel support, compositing, and its powerful 3D environment. We plan on following up this course with a 200-level course during the following term (subject to change). Devereaux has worked at Digital Domain, ILM, RhinoFX and other facilities as a freelance artist, working on films such as Transformers, Fantastic Four: Rise of the Silver Surfer, I, Robot, Star Trek: Nemesis, and others. Class 1 : Overview of the interface and workflow Including reading image files and setting up your working resolutions. A detailed look at the viewer with an introduction to the disk caching system. Brief look at the color space of Nuke and why it's different. This will be detailed in a later class but will be introduced here. Differences between nuke and other popular apps, such as shake and flame will also be illustrated. Class 2: A detailed look at channels and layers Nuke can have up to 64 channels in any script and we will focus on those this week. Using real world examples we will identify the reason for dozens of channels instead of the typical 4, RGBA. From rotoscoping to multi-pass cg compositing, the channels are one of Nuke's best strengths and most unique systems and require some time to understand. Class 3: Compositing Now that we have the basics we will start from scratch assembling a composite. This will introduce many nodes and tools as well as creating a efficient and clean script. Nodes covered this week: Draw tools such as Bezier and Rectangle; Merge tools including Premult, Merge and AddMix; Translate tools; and in-depth looks at the 2 key color correction nodes, Grade and Color Correct. Class 4: The Backbone of Compositing: Keying We will build upon previous weeks and focus on some of nuke's tools for cutting mattes. Focus on the Keyer, the HueKeyer and introduce Primatte and the IBK or Image Based Keyer. This pipeline will also show how to split images into sections and reassemble them as well as creating edge and fill mattes. Class 5: Keying, Part 2 Primatte and the IBK. These tools are far more complex then Nuke's Keyer and far more powerful. Although Primate is used in several apps, Nuke's implementation of it is different and deserves some focus. The IBK on the other hand is completely unique to Nuke and needs more attention and time to understand. Class 6: Color and Color Space What is sRGB? Why does it matter? Unlike most image manipulation applications, Nuke allows the user to choose his/her color space. In most other apps it is chosen for you. Understanding this workflow is crucial for long term success in Nuke. Whether you have an 8 bit jpeg image or a 10 bit Cineon film frame, every thing in Nuke is seen as 32 bit floating point data. This week we will be going over all the color tools found in Nuke and some real world examples that will help you identify which tool is right for which task. Class 7: Nuke Filters Although touched upon here and there through out the course, this week we will focus on Nuke's powerful set of Filters and how to use them. These will include obvious tools such as GodRays, DeFocus, EdgeBlur and lesser known but equally useful filters such as VectorBlur, iDistort and LightWrap. Class 8: 3D System, Part 1 Introduction to the 3D system. We will focus on how nuke deals with 3D objects and how to control the 3D system. A good portion of time will be spent on the 3D interface and the 3D viewer. Since the 2D and 3D components of Nuke are effectively separate entities that must be joined together we will also look at how they work together and how to render your 3D image. Class 9: 3D System, Part 2 This week will focus on the Projector and image mapping as well as importing 3D objects and 3D camera data. We will detail the Render node and go through every parameter. We will also learn how to apply true Motion Blur to your scene in two different ways and why each way is better suited for certain scenarios. Class 10: Efficient Nuking Time to learn how to composite in Nuke the efficient way. This week we will cover optimizing your script for speed and trouble shooting errors such as matte lines and resolution/pixel aspect mis-matches. If you plan to move forward with your Nuke training in a production environment, this session is a can't miss. We will also introduce Nuke's Macro/Custom Tool System called Gizmos. These are extremely powerful and easy to create tools that can be as simple as a default color correction for a particular scene or as complex as a complete assembly of every cg element in a shot. _http://rapidshare.com/files/65951742/FXPHD-nuk101.part17.rar _http://rapidshare.com/files/65951976/FXPHD-nuk101.part01.rar _http://rapidshare.com/files/65952266/FXPHD-nuk101.part02.rar _http://rapidshare.com/files/65952541/FXPHD-nuk101.part03.rar _http://rapidshare.com/files/65952774/FXPHD-nuk101.part04.rar _http://rapidshare.com/files/65953031/FXPHD-nuk101.part05.rar _http://rapidshare.com/files/65953341/FXPHD-nuk101.part06.rar _http://rapidshare.com/files/65953617/FXPHD-nuk101.part07.rar _http://rapidshare.com/files/65953838/FXPHD-nuk101.part08.rar _http://rapidshare.com/files/65954045/FXPHD-nuk101.part09.rar _http://rapidshare.com/files/65954276/FXPHD-nuk101.part10.rar _http://rapidshare.com/files/65954491/FXPHD-nuk101.part11.rar _http://rapidshare.com/files/65954742/FXPHD-nuk101.part12.rar _http://rapidshare.com/files/65954985/FXPHD-nuk101.part13.rar _http://rapidshare.com/files/65955210/FXPHD-nuk101.part14.rar _http://rapidshare.com/files/65955456/FXPHD-nuk101.part15.rar _http://rapidshare.com/files/65955701/FXPHD-nuk101.part16.rar |
30/10/2007, 14:56
Ядро 1-сорт Группа: Пользователи Сообщений: 2 638 Регистрация: 01/10/2005 Из: Moscow Пользователь №: 16 680 |
Эх... а по Fusion бывают такие туторы?
Сообщение отредактировал Yehat - 30/10/2007, 14:56 |
30/10/2007, 15:16
Наш человек Группа: Участник Сообщений: 437 Регистрация: 31/12/2002 Из: Киев Пользователь №: 1 357 |
согласно www.thegnomonworkshop.com, кроме shake и nuke, ничего по композу нет...
30/10/2007, 15:23
Новичок Группа: Пользователи Сообщений: 5 Регистрация: 29/10/2007 Пользователь №: 58 085 |
что-то у cmivfx было. причем довольно много на тему фьюжна. Ежели сильно нужно, могу найти. К тому же по фьюжну есть куча всякого базового хлама на http://www.eyeonline.com/Web/EyeonWeb/Tech...ware/index.aspx, как раз для новичков.
30/10/2007, 15:45
Эксперт Группа: Пользователи Сообщений: 732 Регистрация: 24/01/2006 Пользователь №: 21 895 |
QUOTE согласно www.thegnomonworkshop.com, кроме shake и nuke, ничего по композу нет... Ну Гномоны не пуп туторов, хотя конечно есть у них сильные уроки. ЗЫ FUS101 - Introduction to Fusion и NUK201 - Intermediate Nuke I Coming soon? Сообщение отредактировал jolly_rodger - 30/10/2007, 15:48 |
30/10/2007, 16:31
Знаток Группа: Пользователи Сообщений: 257 Регистрация: 14/08/2007 Из: Москва Пользователь №: 56 105 |
QUOTE(Yehat @ 30/10/2007, 15:56) [snapback]951038[/snapback] Эх... а по Fusion бывают такие туторы? по Fusion есть тутор: CMI VFX Digital Fusion Training kit торрент тута: http://depositfiles.com/files/2206516 размер 3.55гб. про скорость незнаю, но друган один скачал это дело удачно |
30/10/2007, 18:54
спасибо, надо будет разобрацца, попробую качнуть как-нибудь с торрента.
QUOTE(shutty @ 30/10/2007, 18:23) [snapback]951061[/snapback] что-то у cmivfx было. причем довольно много на тему фьюжна. Ежели сильно нужно, могу найти. Буду признателен, если поможешь. Базовое я посмотрел уже. Сообщение отредактировал Yehat - 30/10/2007, 19:00 |
17/09/2008, 13:01
fxphd :: NUK201 Intermediate Nuke I
Taught by Sean Deveraux, this course picks up where the 101 level course left off. Deveraux will be diving deeply into the 3D compositing features of Nuke over the term. Note: This repeat course was recorded using Nuke version 4 (current release is version 5). However, the principles and techniques shown in this course are still fully applicable to the new release. The NUK301 course will be using version 5. Class 1: Warping Nuke has several tools for image distortion and this week we will tackle the grid warp and the spline warp which use shapes to distort an image as well as the iDistort which drives the distortion using an image. Class 2: Advanced Roto and Plate Clean-up Although explored in nuk101, nuke has a lot more control over rotoscoping then previously discussed, such as tracking specific points and importing data from other applications. Class 3: Gizmos The "macro" system in nuke is called gizmos. We will create a gizmo utilizing expressions and user controls and learn how to add that gizmo to our nuke menus for others to access. Class 4: Nuke Customization Building on last week's course, we will further customize nuke by adding and setting default working resolutions on launch, setting up shot specific working directories and other tasks that nuke can automate. Class 5: Nuke Shell Commands We'll cover some common and intermediate shell commands such as rendering without launching the UI and building a script right in the shell. Class 6: 3D: Locating a point in 3D Space It's relatively simple to load camera tracks in nuke but how do you know where to place objects in the scene if you don't have a point cloud or tracking geometry as reference. This week we will go over finding points in Z-space and reconciling 3D track data in 2D. Class 7: 3D Projections One of the key powers to nuke's 3D system is it's ability to project textures onto geometry. This will be our focus this week and will help set up the rest of the semester. Class 8: 3D Set Extensions We will use what we learned in our previous course work to extend a practical set using nuke's 3D system. Class 9: 3D: Set Replacement One of the most challenging and time consuming tasks can be removing some unwanted foreground elements to create a clean plate. The technique we will learn this week has been used in hundreds of shots and saved thousands of hours. Class 10: 3D Multi-Planing Using a single layered frame we will create a camera move and turn our 2-Dimensional image into an active sequence and move through it with our nuke camera. CODE http://rapidshare.com/files/144647035/FXPHD_Nuke_201.part01.rar
http://rapidshare.com/files/144647640/FXPHD_Nuke_201.part02.rar http://rapidshare.com/files/144649508/FXPHD_Nuke_201.part03.rar http://rapidshare.com/files/144649885/FXPHD_Nuke_201.part04.rar http://rapidshare.com/files/144650387/FXPHD_Nuke_201.part05.rar http://rapidshare.com/files/144650638/FXPHD_Nuke_201.part06.rar http://rapidshare.com/files/144650813/FXPHD_Nuke_201.part07.rar http://rapidshare.com/files/144653690/FXPHD_Nuke_201.part08.rar http://rapidshare.com/files/144654029/FXPHD_Nuke_201.part09.rar http://rapidshare.com/files/144654355/FXPHD_Nuke_201.part10.rar http://rapidshare.com/files/144655009/FXPHD_Nuke_201.part11.rar http://rapidshare.com/files/144655141/FXPHD_Nuke_201.part12.rar http://rapidshare.com/files/144655482/FXPHD_Nuke_201.part13.rar http://rapidshare.com/files/144656004/FXPHD_Nuke_201.part14.rar http://rapidshare.com/files/144708836/FXPHD_Nuke_201.part15.rar http://rapidshare.com/files/144712752/FXPHD_Nuke_201.part16.rar http://rapidshare.com/files/144717162/FXPHD_Nuke_201.part17.rar http://rapidshare.com/files/144721001/FXPHD_Nuke_201.part18.rar http://rapidshare.com/files/144724845/FXPHD_Nuke_201.part19.rar http://rapidshare.com/files/144728616/FXPHD_Nuke_201.part20.rar http://rapidshare.com/files/144732105/FXPHD_Nuke_201.part21.rar http://rapidshare.com/files/144735568/FXPHD_Nuke_201.part22.rar http://rapidshare.com/files/144739071/FXPHD_Nuke_201.part23.rar http://rapidshare.com/files/144742622/FXPHD_Nuke_201.part24.rar http://rapidshare.com/files/144746049/FXPHD_Nuke_201.part25.rar http://rapidshare.com/files/144751476/FXPHD_Nuke_201.part26.rar http://rapidshare.com/files/144755170/FXPHD_Nuke_201.part27.rar http://rapidshare.com/files/144758472/FXPHD_Nuke_201.part28.rar http://rapidshare.com/files/144761801/FXPHD_Nuke_201.part29.rar http://rapidshare.com/files/144765337/FXPHD_Nuke_201.part30.rar http://rapidshare.com/files/144775215/FXPHD_Nuke_201.part31.rar http://rapidshare.com/files/144778400/FXPHD_Nuke_201.part32.rar http://rapidshare.com/files/144781917/FXPHD_Nuke_201.part33.rar http://rapidshare.com/files/144784640/FXPHD_Nuke_201.part34.rar http://rapidshare.com/files/144874139/FXPHD_Nuke_201.part35.rar http://rapidshare.com/files/144894623/FXPHD_Nuke_201.part36.rar http://rapidshare.com/files/144899388/FXPHD_Nuke_201.part37.rar http://rapidshare.com/files/144904129/FXPHD_Nuke_201.part38.rar http://rapidshare.com/files/144909540/FXPHD_Nuke_201.part39.rar http://rapidshare.com/files/144914544/FXPHD_Nuke_201.part40.rar http://rapidshare.com/files/144919452/FXPHD_Nuke_201.part41.rar http://rapidshare.com/files/144924674/FXPHD_Nuke_201.part42.rar http://rapidshare.com/files/144930274/FXPHD_Nuke_201.part43.rar http://rapidshare.com/files/144935748/FXPHD_Nuke_201.part44.rar http://rapidshare.com/files/144941519/FXPHD_Nuke_201.part45.rar http://rapidshare.com/files/144947077/FXPHD_Nuke_201.part46.rar http://rapidshare.com/files/144952989/FXPHD_Nuke_201.part47.rar http://rapidshare.com/files/144958534/FXPHD_Nuke_201.part48.rar http://rapidshare.com/files/144964306/FXPHD_Nuke_201.part49.rar http://rapidshare.com/files/144970420/FXPHD_Nuke_201.part50.rar http://rapidshare.com/files/145011746/FXPHD_Nuke_201.part51.rar http://rapidshare.com/files/145014641/FXPHD_Nuke_201.part52.rar http://rapidshare.com/files/145017618/FXPHD_Nuke_201.part53.rar http://rapidshare.com/files/145020547/FXPHD_Nuke_201.part54.rar http://rapidshare.com/files/145029816/FXPHD_Nuke_201.part55.rar http://rapidshare.com/files/145032857/FXPHD_Nuke_201.part56.rar http://rapidshare.com/files/145035718/FXPHD_Nuke_201.part57.rar http://rapidshare.com/files/145038609/FXPHD_Nuke_201.part58.rar http://rapidshare.com/files/145041521/FXPHD_Nuke_201.part59.rar http://rapidshare.com/files/145126825/FXPHD_Nuke_201.part60.rar http://rapidshare.com/files/145130039/FXPHD_Nuke_201.part61.rar http://rapidshare.com/files/145131151/FXPHD_Nuke_201.part62.rar |
17/09/2008, 14:22
S.T.A.R.P.E.R. Shadow Of Leningrad Группа: Участник Сообщений: 942 Регистрация: 17/06/2002 Из: Советский Союз Пользователь №: 35 |
вот спасибо!
кстати, появился сабж по теме http://homepage.ntlworld.com/matthew.leona...iningDVD_02.htm никто не встречал? может скинемся миром? |
17/09/2008, 14:51
Откуда, он тока на медне вышел.
Тут или ждать милостей от природы, или шапку по кругу. |
17/09/2008, 16:37
можно и шапку.. диск порядка 100-150$ (не помню)
я б дал часть. даже человек 5 - уже дешево получается. кто еще |
17/09/2008, 16:44
самоучитель Группа: Участник Сообщений: 2 850 Регистрация: 12/02/2004 Пользователь №: 4 541 |
+1
17/09/2008, 17:04
Знаток Группа: Пользователи Сообщений: 287 Регистрация: 11/02/2008 Пользователь №: 61 534 |
Идиотский вопрос наверное, но что лучше Nuke или Fusion
17/09/2008, 17:19
сравни, выбери, на картинке все видно
http://pics.livejournal.com/wpiggy/pic/0000er3a |
17/09/2008, 17:21
indiso какая отвёртка лучше, лопатообразная или крестобразная?
Извини по другому ме могу сравнить. Я готов принять участие |
| Bots |
Текстовая версия | Сейчас: 08/09/2010 - 03:04 |
