| Home· Статьи · Downloads · Чертежи · 3D Галерея · 2D Галерея · Форум · Форум Realtime · Чат | Реклама |  Конкурсы | RAR Award | Правила |
08/11/2006, 02:12
#46
Бывалый Группа: Пользователи Сообщений: 122 Регистрация: 19/10/2006 Из: Украина Пользователь №: 38 797 |
Digital tutors - Facial animation and lip sync for Maya
![]() Description Learn innovative and time-saving facial animation and lip sync techniques in Maya with over 6.5 hours of project-driven training. Perfect for intermediate artists. Popular highlights include: * Animating to Dialogue * Lip Syncing * Principles of Emotion * Referencing Footage * Mechanics of Facial Animation * Timing and Spacing * Anticipation * Animating Arcs * Pose to Pose * In-betweening * Follow-through * Head Subtleties * Facial Expressions * Graph Editor * Working with Shot Camera * Animating with Simplicity * Show Buffer Curves * Editing Tangents ------------------------------------------- Software Requirement: Maya 7 Run Time: 6 hrs. 14 min., 2 discs CD1 хттп://rapidshare.com/users/4YYCQI CD2 хттп://rapidshare.com/users/25V75D pass - otto |
08/11/2006, 13:51
#47
илюша) Группа: Пользователи Сообщений: 1 462 Регистрация: 06/03/2006 Из: зИ! Пользователь №: 24 617 |
Есть что-нибудь для "Макса"? Желательно по анимации персонажей, моделированию сплайнами, работы с шерстью и частицами, и по vidopost'у
Сообщение отредактировал Eol-dark_elf - 08/11/2006, 13:55 |
09/11/2006, 01:56
#48
CG Academy Particle Flow Fundamentals 5 : Practical Examples
![]() Description Practical Examples concludes our Particle Flow Fundamentals series with an in depth look at nine diverse real world effects. We look at how to approach each example in the most efficient manner, how different flow topologies can be used to tackle different effect problems. How materials can be used to produce animated effects, and how animated meshes can be instanced into our flows to help in realising our compelling series of effects. This DVD is aimed at a user with a basic knowledge of Particle Flow. It has been primarily designed as a continuation of our Particle Flow Fundamentals series, though it is also very much suitable for those of an intermediate level of Particle Flow use. Download : 54 part, 53 x 50MB + 8,8MB, хттп://rapidshare.com/users/SZ815O Password : shareislove Сообщение отредактировал sharkiserg - 09/11/2006, 01:57 |
09/11/2006, 02:30
#49
Советчик Группа: Пользователи Сообщений: 78 Регистрация: 28/10/2004 Из: Moscow Пользователь №: 7 994 |
09/11/2006, 13:53
#50
CG user Группа: Участник Сообщений: 1 320 Регистрация: 06/12/2002 Из: Москва Пользователь №: 1 246 |
sharkiserg - по XSI есть что нибудь? сенкс!
09/11/2006, 18:50
#51
QUOTE(gena @ 09/11/2006, 14:53) [snapback]749981[/snapback] по XSI есть что нибудь? сенкс! java script:emoticon(':no:', 'smid_22')к сожалению нет.... только по maya и 3ds max |
11/11/2006, 01:06
#53
Эксперт Группа: Пользователи Сообщений: 631 Регистрация: 22/05/2004 Пользователь №: 5 962 |
http://www.tutorials3d.com/eng/tut_sheet.asp?tut_id=15
у кого-нибудь вот это есть? |
11/11/2006, 10:41
#54
Рыцарь форума Группа: Участник Сообщений: 3 526 Регистрация: 21/06/2002 Пользователь №: 125 |
QUOTE(gena @ 09/11/2006, 14:53) [snapback]749981[/snapback] sharkiserg - по XSI есть что нибудь? сенкс! Digital tutors Next - Generation Game Techniques in XSI www.digitaltutors.com/store/product.php?productid=1761
11/11/2006, 19:10
#55
Учитель Группа: Пользователи Сообщений: 335 Регистрация: 05/03/2004 Пользователь №: 4 884 |
http://www.progs.kiev.ua/forum
На сайте выкладывают Гномоны и СиДжиАкадеми прямые линки (без рапиды и все такое), но скорость 10 Кб. |
11/11/2006, 20:16
#56
MaxMan Группа: Пользователи Сообщений: 237 Регистрация: 11/02/2006 Пользователь №: 23 089 |
QUOTE(Grover @ 11/11/2006, 20:10) [snapback]751324[/snapback] http://www.progs.kiev.ua/forum На сайте выкладывают Гномоны и СиДжиАкадеми прямые линки (без рапиды и все такое), но скорость 10 Кб. П**********Ж от силы 7 а на сайте указано 5 и в один поток Сообщение отредактировал DIMOHIUS - 11/11/2006, 20:18 |
11/11/2006, 20:44
#57
Уважаемый Группа: Пользователи Сообщений: 820 Регистрация: 26/05/2004 Пользователь №: 6 004 |
вопрос про рапидшару.
Там обычно файлы разбиты на несколько архивов. Скачав один архив, второй уже не скачивается... в чём прикол ? |
11/11/2006, 23:56
#58
Наш человек Группа: Участник Сообщений: 441 Регистрация: 29/08/2005 Пользователь №: 15 941 |
QUOTE(DIMOHIUS @ 11/11/2006, 21:16) [snapback]751348[/snapback] QUOTE(Grover @ 11/11/2006, 20:10) [snapback]751324[/snapback] http://www.progs.kiev.ua/forum На сайте выкладывают Гномоны и СиДжиАкадеми прямые линки (без рапиды и все такое), но скорость 10 Кб. П**********Ж от силы 7 а на сайте указано 5 и в один поток Я качаю оттуда на скорости 400 Кбайт\сек.!!!! Есть низкая скорость на некоторых файлах конечно, но все-таки... |
13/11/2006, 23:34
#60
вот BABU еще урок выложил
Gnomon - Camera Projection Techniques in Maya ![]() info In this DVD, Darin takes you through the production and completion of a camera projected 3D Matte painting using Autodesk Maya and Adobe Photoshop®. Darin covers the essential techniques and solutions for 3D matte painting as he progresses from rough concept to modeling, rendering and creating the painting in Photoshop®. After bringing the finished matte painted layers back into Maya, he describes how to apply them in the scene. Darin also shows methods for solving common texture distortions with additional projections. Finally, he demonstrates simple techniques for bringing life to your scenes. Over 3 1/2 hours of lecture. Product Code: DHI01 Camera Setup Modeling for Projection Camera Animation Photoshop® Setup and Painting Projection Setup Shader Setup Image Re-Projection Atmospherics and Light Passes 01: Introduction to Camera Projection 02: Modeling and Projection Setup 03: Photoshop Techniques 04: Maya Projection Setup 05: Secondary Projections 06: Atmospherics and Light Passes 07: Final Compositing http://rapidshare.com/files/3107216/CPT.part01.rar.html http://rapidshare.com/files/3109264/CPT.part02.rar.html http://rapidshare.com/files/3111224/CPT.part03.rar.html http://rapidshare.com/files/3112921/CPT.part04.rar.html http://rapidshare.com/files/3114560/CPT.part05.rar.html http://rapidshare.com/files/3116354/CPT.part06.rar.html http://rapidshare.com/files/3118053/CPT.part07.rar.html http://rapidshare.com/files/3119696/CPT.part08.rar.html http://rapidshare.com/files/3121145/CPT.part09.rar.html http://rapidshare.com/files/3122715/CPT.part10.rar.html http://rapidshare.com/files/3124190/CPT.part11.rar.html http://rapidshare.com/files/3125491/CPT.part12.rar.html http://rapidshare.com/files/3126761/CPT.part13.rar.html http://rapidshare.com/files/3128080/CPT.part14.rar.html http://rapidshare.com/files/3129100/CPT.part15.rar.html http://rapidshare.com/files/3130385/CPT.part16.rar.html http://rapidshare.com/files/3131904/CPT.part17.rar.html http://rapidshare.com/files/3133048/CPT.part18.rar.html http://rapidshare.com/files/3134049/CPT.part19.rar.html http://rapidshare.com/files/3135004/CPT.part20.rar.html http://rapidshare.com/files/3135931/CPT.part21.rar.html http://rapidshare.com/files/3136370/CPT.part22.rar.html pass : gfxgfx.net |
| Bots |
Текстовая версия | Сейчас: 03/09/2010 - 04:13 |
