Quick Brick, tutorial |
08/06/2003, 14:32
Эксперт Группа: Участник Сообщений: 518 Регистрация: 25/02/2003 Из: Vancouver, Canada Пользователь №: 1 524 |
Ya nachal pisat' phonetikoi, no sdalsia srazu.
Mozhet kto perepechataet na Russian? Preface We all need "good" textures to work with. What is a "good" texture? I've found it's the one that has enough detail for a medium-range shot and doesn't create patterns over vast surfaces. It's nice to have a photograph, but not always possible. Also, a photograph that looks cool looses all charm when tiled x20, and it creates patterns. There are things like Noise and Fractal Noise that are supposed to be "random". Unfortunately, their "randomness" quickly become repetitive since it's generated by the same algorythm. Here we will use some "Scrawnypaws Secret Solutions" to quickly make a Diffuse Brick texture which would cover the whole Moscow Kremlin without repeating itself even once - to an untrained eye, of course. Please, note - these are principles only that you are free too use and develope further. This is NOT a ready commercial-quality texture - to make one is up to you. Files used here are 3 years old and scaled down for the Web, but the principles have not aged. Getting Started We need a basic Layer texture that has some detail to it. Since we're not using Noise, let's make Mother Nature work for us. In this case I took watercolor paper and "washed" it with brownish color in several passes. When scanned into Photoshop, it gave me a 2048 size file of a surface like this - ColorGrain_Detail_01. I used this file ever since. The beauty of this is that it is really a random Grain. Make it Seamless, of course, and Clone Stamp out any spots that look too prominent. Check for repeats, when tiled, say x3. We want something that looks detailed up-close and rather uniform from a distance. |
08/06/2003, 14:34
Basic Texture
Open/Name Layer " Base"/ Select/Color Range/ Tolerance (set low, 15-35)/Picker click on darkest spot/ QickMask( to check if the selected pixels/grains are spaced enough; if not, change the Tolerance some)/Exit QuickMask Select/Transform Selection/Flip(or rotate 180) Horizontal (for example, we don't want the pixels we're going to cut out to correspond to the existing grain- Random is our motto) Copy/Paste/Name Step01 We don't need all of it, so another selection mask is needed. I use the Universal Blot for it - it was created by multiple selected parts of a tree foliage, so it doesn't have a "hand-made" aspect. Open/Select All/Copy go to our file, Paste All Layers off (save the Blot one, and better have a white background - sometimes selection tools select pixels partially, if on a transparent Background) Select Color Range/Blot Layer off/go to Step01/move Selection where you fancy, Delete pixels, repeat at will Base Layer on/Image/Adjust/Hue-Saturation(change to your taste) this gives Step_01 image (I added a black background to make it more visible, yours is without it) Repeat - in our case 3 times (flipping Color Range Selection each time different way) - as many times as you need. This makes Steps 02 and 03. All Layers on/Save - Step 04 image. This kind of texture can be advanced to any degree of realism. |
08/06/2003, 14:35
step 01
08/06/2003, 14:36
step 02
08/06/2003, 14:37
step 03
08/06/2003, 14:38
step 04
08/06/2003, 14:39
Seams
Make a seam B/W mask ( whatever pattern) You can use a Stucco.jpeg that comes with MAX as a texture Copy/Paste the Seam mask into the file/Stucco layer off Select Color Range(black)/Stucco on, go to/Copy/Paste/Name "Seams" Let's give the Seams some volume All Layers off, Seams Mask on/Select Color Range, layer off/go to Seams/ Move Selection 1 pixel 45deg up-left/Select Inverse/ ( here you may want to add Feather 0.5-1 pix to make it smooth) /Image/Adjust/Brightness-Contrast (dark, this is the shade of the seams) Same for the highlight. Save. You may want to do the same to Bricks, like in the Fake_Volume_01 image. This principle applies to all digital painting. Copy/Paste into Bricks File - here we are - Bricks Final pic. This is only a diffuse Map. Using your own Universal Blot, you can make surfaces like this -Blotty_01_Detail, combine them with seams and use as a Bump Masks. This brick, with a different seam pattern was used in the "Tosca" Production Paintings. |
08/06/2003, 14:39
seams final
08/06/2003, 14:40
volume
08/06/2003, 14:42
brick final
08/06/2003, 14:42
Universal Blot
08/06/2003, 14:43
blotty_detail_01
08/06/2003, 14:45
Advanced Materials Secret Tip
Make it a Blend or use a Mix Map (renders slightly faster, but with Blend you control other properties, like Gloss etc...). Make a second Brick diffuse (darker, different blots etc) Make a Mixing Map using the Universal Blot technique. Map with Box Gizmo (so your texture would have the same scale everywhere) and make the Box at least 2 times bigger than your object. Tile the Base maps as much as needed. Tile the Mixing Map ONLY BY ONE. This way, if you have several similar objects (walls etc) you won't have to make a new and different material each time. Just move the Gizmo (up/down etc) - it will look different, because there are NO REPEATS in the Blotty Mixing Map. I use this mapping method now on the Crystal Key 2 (Adventure), where I model the main area. There is an enormous quantity of railings, metal panels and such, so one simply can't have a lot of hi-res maps - MAX chokes on it. |
08/06/2003, 17:55
cute tutorial. I'm sure it will be useful, especially for lovers of "I'll do all myselfing".
thanks! |
08/06/2003, 19:11
Уволился Группа: Участник Сообщений: 2 561 Регистрация: 06/07/2002 Из: Санкт Петербург Пользователь №: 289 |
2scrawnypaws: Спасибо тебе большое за такое благое дело! Но я знаю, что многие плохо владеют английским языком, но это не значит, что им не интересно, так что пожалуй я тоже начну благое дело. Пока перевел только первый пост - если понравится могу и продолжить. Но надеюсь, что и еще кто нибудь присоеденится, т.к времени перевести все у меня даже близко нету.
Вот оцените. Мы все нуждаемся в «хороших» текстурах. А что такое «хорошая текстура»? Я бы сказал, что это такая текстура, которая обладает достаточной детализацией для наблюдения со средней дистанции и не создает повторяющихся участков на обширных поверхностях. Неплохо было бы иметь фотографию, но это не всегда возможно. И кроме того, фотография, которая смотрится неплохо теряет весь свой шарм после двадцатикратного размножения и опять же создает повторяющиеся участки. Существуют такие вещи, как Noise (Шум) и Fractal Noise (Фрактальный шум) и они должны быть беспорядочными, случайными. Но к сожалению их случайность вскоре становится однообразной поскольку они все создаются одними и теми же алгоритмами. Далее мы будем использовать «Секретные решения Scrawnypaws’а» для быстрого создания карты рассеивания в виде кирпичиков, которая покроет всю Кремлевскую стену не повторяя себя ни разу – естественно для неопытного глаза. Учтите, что это только принципы, которые вы все свободны использовать и развивать дальше. Это не готовая текстура коммерческого качества – создание, которой зависит от вас. Файлы использованные далее трехлетней давности и «масштабированы для сети», но принципы не устаревают. Начнем. Нам нужен основной текстурный слой, который обладает детализацией. Поскольку мы не используем шум (Noise), предоставим матушке природе поработать за нас. В данном случае я взял акварельный лист и покрыл его коричневатым цветом за несколько проходов. После сканирования мы получили файл размером в 2048 со следующей поверхностью: ColorGrain_Detail_01. Я использую его уже давно. Вся его прелесть в том, что это действительно случайное «зерно». Конечно, начните с того, что сделайте его бесшовным и с помощью инструмента Clone Stamp уберите те места, которые слишком выделяются. Проверьте на повторения скажем при трехкратном размножении. Мы хотим получить нечто, что будит выглядеть достаточно детализировано при близком рассмотрении, и достаточно единообразно с расстояния. |
Текстовая версия | Сейчас: 24/04/2024 - 08:47 |
