Fryrender sp2, жив, курилка |
24/03/2009, 23:24
Мастер Группа: Пользователи Сообщений: 1 018 Регистрация: 10/12/2005 Пользователь №: 19 309 |
QUOTE Hello fryers, As some of you know already, fryrender one SP2 was uploaded to our server a few hours ago. SP2 (Service Pack 2, or 1.2, if you like) is a big leap forward in terms of quality and speed. As explained in other announcements, some very remarkable things have happened to the rendering core. The most important one is that after some deep post-Release1 profiling and clean-up, fry SP2 is about 20% faster than its predecessor SP1. More than that, some other very important improvements have been made in the Anti-Aliasing, and the random number generation systems, which have led to a more pleasant noise over time, and a superior very fine yet really smooth AA. Importance-Sampling-driven IBL is back for good in this version, and it has been enhanced a bit to make it cope better with scenes where caustics are involved. Many other minor fixes and improvements have happened in different parts of the core, which you may not even notice, that will produce significantly better renders. For example, our atmospheric system has been sRGB-corrected, Kelvin colors have been normalized, and the tonemapping has been extended to react better when colors are overpowered by a strong source of light. All in all, SP2 is the best fryrender to date by far, and we're eager to see what you can do with it. плюс к тому появился Frybench, тестер мощности рендер-машинки, будем посмотреть. |
25/03/2009, 00:48
Мастер Группа: Пользователи Сообщений: 1 049 Регистрация: 13/01/2005 Из: Kiev Пользователь №: 9 454 |
Я вот только не понял ,
Его опять чтоли покупать нужно.."""""""""""""*???? Как то у них не ответа ни привета.. |
25/03/2009, 02:17
creator Группа: Участник Сообщений: 2 012 Регистрация: 28/11/2004 Из: moscow Пользователь №: 8 582 |
продолжение поста Чемы на оффоруме
Цитата A mailing will be sent out shortly. We are aware that our latest newsletter about SWAP 1.1 was not received by some people, so we have put up a new section in our website called 'Most Recent Newsletters' where you will find a persistent copy of all our newsletters from now on. http://www.randomcontrol.com/newsletters As a matter of fact, the newsletter you should receive by email in a while shows up there already. Гигакстер, отмылят в ближайшее время всем юзерам.. |
28/03/2009, 01:07
ну вот и зарелизили..
fryrender one SP2 has been released!!! Dear reader, March 2009 has been an important month to us, as we have had 3 new releases: 1- fryrender one SP2 2- SWAP v1.1 3- frybench.com This newsletter revolves around the release of fryrender SP2, the biggest leap forward in our light simulation technology since the Release Candidate. The newsletter elaborates a bit on why SP2 is the best fryrender to date, and what has changed since SP1. On the other hand, a brief description on what's new in SWAP 1.1 and what's frybench.com is provided. Note for our fryrender or SWAP customers: You can upgrade yourself by downloading the new setups from the usual location. Note that SP1 licenses are compatible with SP2, so you won't need to re-activate your products. To avoid unnecesary re-activation requests, please make sure that you backup your license.ini file in a safe location before you install the new setup. Note for our fryrender DEMO users: The DEMO version of fryrender has been upgraded to SP2 as well, and it is available for download from our website www.fryrender.com as usual. >> SP2 is about 20% FASTER than SP1 << This speed gain is the result of a deep revision, clean-up and optimization of our rendering core, which has led to better code. No cheats, shortcuts, biases, or any fundamental changes in the technology have been involved whatsoever. The following animated .GIFs depict this assertion: This is the detailed changelog for SP2: Additions & improvements - 20% faster rendering core - Importance-Sampling IBL is working again - Definitive Anti-Aliasing system - IBL will render caustics and certain GI situations more smoothly now - Better tonemapping for burnt-out tones - sRGB-corrected physical sky hues - Material auto-conversors are supporting .PNG / .TIF now - Added support for mouse-wheel in the UI Bug fixes - Fixed some glitches in the UI - Old multi-threading conflicts when using several instances of the standalone are fixed - Fixed scrollbars in the UI - Fixed Light UI - Fixed problems with cropped sliders when resizing the UI - Fixed .TGA vertical flip in some .TGA files - Fixed bug that would make .TGA files fail to save under RAM-stressed situations - The OBJID buffer will keep the same colors through all the frames in an animation now - Random colored spots in the framebuffer at very high efficiency (10000+) values fixed - All Kelvin colors will now carry the same average power regardless of their temperature Warnings for existing users - .DSIs generated with versions older than SP2 will not load properly in SP2 Note for our fryrender or SWAP customers: You can upgrade yourself by downloading the new setups from the usual location. Note that SP1 licenses are compatible with SP2, so you won't need to re-activate your products. To avoid unnecesary re-activation requests, please make sure that you backup your license.ini file in a safe location before you install the new setup. Note for our fryrender DEMO users: The DEMO version of fryrender has been upgraded to SP2 as well, and it is available for download from our website www.fryrender.com as usual. Сообщение отредактировал rafter - 28/03/2009, 01:15 |
28/03/2009, 01:19
MaxMan Группа: Пользователи Сообщений: 233 Регистрация: 01/09/2007 Из: Dnipropetrovs'k Пользователь №: 56 513 |
ага я тож такое на мыло получил... только не могу найти откуда демку скачать..
28/03/2009, 01:34
вот тут форма..
http://randomcontrol.com/index.php?option=...e&Itemid=35 по заполнении выдадут ссылку Сообщение отредактировал rafter - 28/03/2009, 01:35
28/03/2009, 01:40
Rafter пасиб но сам нашел,, уже качаю, закончу через час,, сейчас нарисую тестовую сцену на три материала, сделаю рендеры а потом с утра поставлю SP2 и сравню результаты..
fryrender one SP2 DEMO (32-bit) - (zip 51MB) http://randomcontrol.com/downloads/demos/R...O_v20090321.zip fryrender one SP2 DEMO (64-bit) - (zip 51MB) http://randomcontrol.com/downloads/demos/R...O_v20090321.zip Сообщение отредактировал mey - 28/03/2009, 01:46 |
28/03/2009, 12:27
ну интерфейс чуть изменили, пока прошло 2мин. тестовой сцены уже могу сказать что стало быстрее..
28/03/2009, 12:32
уточки на них, я так понял, так и не намечается?)
28/03/2009, 13:14
Наш человек Группа: Пользователи Сообщений: 493 Регистрация: 18/02/2007 Пользователь №: 44 874 |
на сп1 была утка??? еси нет на сп1 откуда на сп2 выростет?
28/03/2009, 13:23
Двоякие впечатления начальные обновления картинки происходят быстрее, потом в сумме это выглядело так: было 42.5 мин. стало 31.9 мин.,, а теперь сравнение результатов..
Картинка стала светлее, а стекло стало не прозрачное,, ,, может конечно я чего-то недосмотрел и не докрутил,, но очень сомневаюсь, качество картинки осталось тоже :-( .. теперь мне очень интересно посмотреть на следующий пасес может стекло станет прозрачное.. |
28/03/2009, 13:30
28/03/2009, 13:43
а жаль:) вот есиб китайцы взялись за утку:)хотям ватеры и ограничение по размеру убрали бы
Сообщение отредактировал BlesS - 28/03/2009, 13:55 |
28/03/2009, 14:27
прозрачности не дождался..
оставил только один шар задал ему самое прозрачное стекло, и поставил снова не рендер.. |
28/03/2009, 14:33
с увеличение света "прозрачность" становится нормальная..
А еще кто-то поделится результатами?? |
Текстовая версия | Сейчас: 19/04/2024 - 13:33 |
