3delight 7.0, Обновился |
07/12/2007, 19:05
Эксперт Группа: Пользователи Сообщений: 753 Регистрация: 13/06/2004 Из: Russia, Spb Пользователь №: 6 228 |
CODE 3DELIGHT 7.0 ============ 3Delight For Maya * The plug-in is better integrated into Maya. It now registers itself as a standard Maya renderer and is thus accessible through the Render Settings. Batch rendering and command line rendering (through the standard Maya `Render' command) is now possible. * Improved HyperShade Translation: - 3Delight For Maya tracks HyperShade network modifications and only translates and compiles shaders which have changed. - The following hypershade nodes are now supported: ocean, remapValue, lightInfo, layeredTexture and volumeLight. The Image Sequence options of the File texture node are now supported. - HyperShade networks for light sources are correctly translated into their RenderMan SL equivalent. - The RenderMan Code shader can now declare output variables and those can be output using secondary displays (advanced). * Support for RIB archives creation and reading using a user friendly, yet flexible, interface. * Out-of-the-box support for Shave & a Haircut and much improved Maya Fur support. * Object Instancers are fully supported. * Shadow Maps can be rendered using arbitrary cameras. This allows for better shadow map view framing and thus better quality. * More output variables added to secondary displays. * Maya 2008 support. Rendering Features * New Image Based Lighting Algorithm. A more flexible and powerful approach to image based lighting is introduced. * Point Based Occlusion and Color Bleeding. * Brick Maps (3D Textures) for efficient and anti-aliased 3D data lookup. * Display subsets. A unique feature that enables rendering of many layers, each with its own alpha channel and output variables, in one render pass. 3Delight Performance * Multi-threading efficiency has been improved for scenes with high depth complexity. * Point cloud files are not read in memory all at once any more: proper caching enables memory-efficient access to point cloud data. * Subsurface scattering has been optimized and the pre-processing step is now run in multi-threaded mode. * Deep Shadow Map creation is now multi-threaded. * `occlusion()' and `indirectdiffuse()' have been accelerated through the use of adaptive sampling. Texture Converter (`tdlmake') A new `-preview' option makes `.tdl' textures appear as TIFFs of lower resolution to software such as Maya; this enables you to use a single texture for both Maya previews and final renders. Additionally, `tdlmake' now supports the TARGA file formats. New Tools * `ptc2brick' is a tool to convert point cloud files to brick maps. * `ptcview' is a tool to view point cloud files. * `ptcmerge' is a tool to merge point cloud files. Pipeline * A new API to access point cloud files has been added. * A C++ API for DSO plug-ins is now available. лекарство от 6.5 походит... З.Ы. Отличная альтернатива прман'у |
07/12/2007, 21:32
Рыцарь форума Группа: Участник Сообщений: 3 539 Регистрация: 21/06/2002 Пользователь №: 125 |
в 6.5 вроде длл подменять надо было....так ты что эту длл от 6.5 использовал?они одинаковые?
07/12/2007, 21:41
2 yuri:
Там не длл, а лиценз_сервер + лицензия.. Я попробовал завести 7.0 с лечилкой от 6.5 - все работает.. |
07/12/2007, 22:26
хм...странно, я тоже пробовал:поменял,запустил
licserver license.dat в ответ в консоле licserver: 2007/12/07 21:25:31: unable to load license file (license.dat) по этому и подумал-может еше чего не хватает(длл,so) |
08/12/2007, 13:45
ок-работает!
разобрался-утро вечера мудренее :-) |
11/12/2007, 18:52
непойму лицензию схавал нормально, но плагин к майе не хочет запускаться,
я прописал в PATH путь к папке с плагами, но в майе (8,5) выбираю в плагн 3делайт фор мая 8,5 - выдаёт следующее CODE // Error: Unable to dynamically load : C:/Program Files/3Delight/maya/plugins/3delight_for_maya8.5.mll The specified module could not be found. // // Error: The specified module could not be found. // // Error: The specified module could not be found. (3delight_for_maya8.5) // // Error: Unable to dynamically load : C:/Program Files/3Delight/maya/plugins/3delight_for_maya8.5.mll The specified module could not be found. // // Error: The specified module could not be found. // // Error: The specified module could not be found. (3delight_for_maya8.5) // createModelPanelMenu modelPanel1; createModelPanelMenu modelPanel2; createModelPanelMenu modelPanel3; createModelPanelMenu modelPanel4; buildPanelPopupMenu scriptEditorPanel1; C гудини всё работает на ура Сообщение отредактировал witcher - 11/12/2007, 18:53 |
28/12/2007, 14:17
Вопрос к тем кто пробовал и последний 3delight и последний рман (13.5)
Как Вы думаете где скорость рейтрейса больше. Имеется ввиду по общим впечатлениям. Ну и можно упомянуть например ареалайты. Я, понятное дело, склоняюсь к тому что рман побыстрее или примерно одинаково, но всеже... Ваше мнение... |
10/01/2008, 12:52
Наш человек Группа: Участник Сообщений: 436 Регистрация: 07/01/2004 Пользователь №: 4 147 |
на хомяке вчера выложили несколько фри уроков
ввв.3delight.com/en/index.php/products/3delight_for_maya/tutorials по 3Delight For Maya |
10/01/2008, 13:11
2 VUX:
Серьезных замеров не делал.. Недавно сценку посчитал для сравнения в HD(1920x1080): (Шарики(энвармент текстура+ретрейс+диспл), пол(диспл), доф, 1 спотлайт+дипшадоус, ). с одинаковым сеттингом. 3делайт был немного быстрее.. 2 SINE: спасибо за ссылко |
11/01/2008, 16:47
забавно.. в одном уроке промелькнуло, что их у автора 15 штук, а на сайте пока лежит 5.
14/01/2008, 14:36
списался с автором уроков Paolo Berto, вот что он ответил:
"you gotta wait. 6-12 are scheduled for feb 12-18 for march" так что - ждёмс |
14/01/2008, 17:22
ЗдОрово! Ждемс.. В целом мне 3Dl сильно симпатизирует
18/01/2008, 13:39
3Delight v7.0 for OSX (intel), таблетко внутрях
_w14.easy-share.com/15246761.html 9.5 метра парол:koleso удачи! Сообщение отредактировал SINE - 18/01/2008, 13:40 |
08/04/2009, 00:43
Здрасти всем ! У меня такая проблема -перешел с Макса на Синему11 и хочу установить 3delight-8.0.1 -ключик они мне уже выслали -кинул его в корневик ,поменял длл непомогает :unable to load license file (license.dat) и если нетрудно ссылочку на более свежую версию если есть! плиз помогите ну оч хочется поюзать ! верей нехочу т.к стандартный делает его и так и сяк.
09/04/2009, 16:16
Здрасти всем ! У меня такая проблема -перешел с Макса на Синему11 и хочу установить 3delight-8.0.1 -ключик они мне уже выслали -кинул его в корневик ,поменял длл непомогает :unable to load license file (license.dat) и если нетрудно ссылочку на более свежую версию если есть! плиз помогите ну оч хочется поюзать ! верей нехочу т.к стандартный делает его и так и сяк. Вроде как для Майи и Кси существует 3delight, если не ошибаюсь... Причем здесь Синема? |
Текстовая версия | Сейчас: 25/04/2024 - 19:07 |
